Kraton new car checks?
turfRC
  1. BigRock 4x4
just got my new kraton 6s v5. ran about 3 packs through it and all seems good. what specifically should i be aware of to check on for this car?
thanks
recommendation on which you tube video to help explain and show
Shim your wheel hex's.. check dog bones aren't bent and make sure diffs are shimmed proper after u pull them all and top them off!! Set your droop screws as well!!🤙
Adjust droop screws so you take pressure off the shock ends. I also shimmed at my wheel hex to remove some of the slop.
