- Middle Tennessee
- Felony
- Infraction
- Kraton 8S
- Kraton 6s
- Outcast 8s
- Talion
- Typhon 3s
I guess not. That’s straight from Castles website.
Impressive! Going to hit 200 in no time!Raz posted up a few 190 mph runs and a 192 mph as the peak he could pull off with the 1721
Certainly more speed than I expected from this size motor and KV.
Seems like getting to 180 is no big deal with this motor
I imagine there's a super fine line between over gearing this motor.but if you get it just right I bet it's going to flyHaving that runway is a big deal. He needed 3000+ feet to pull that off.
He had to let that motor wind up to 60k - 65k rpms (ignore what he shows in the logs)
Cannot emphasize enough to not over gear this motor. I was looking at setups over 150mph and you could do it with a 42t spur and a 24t pinion with this high of a KV. (using 2.8 ratio diffs)
Getting to 140mph is a big deal These pros make it look easy. What James has done on that skinny road is amazing. Raz has the luxury of a private 4 lane runway with a gyro and it’s still very hard at that.Seems like getting to 180 is no big deal with this motor
Ordered
Yes if people put in their Limitless 34/27 gearing it will burn up in a hurry. I suspect lots are going to do it too...I imagine there's a super fine line between over gearing this motor.but if you get it just right I bet it's going to fly
It also seems to lack braking power, so I bet there will be runaway firesYes if people put in their Limitless 34/27 gearing it will burn up in a hurry. I suspect lots are going to do it too...
That is gearing with 2400kv for over 200mph
I bet some will try 34/34 also and really over do it....
Isnt it braking that heats the motors up a lot?It also seems to lack braking power, so I bet there will be runaway fires
YepIsnt it braking that heats the motors up a lot?
I saw Raz's video with the 1/5 scale road car with the castle system and the ESC blew up because of all the braking with such a heavy car
Braking with speed gearing requires a ton of torque as does the acceleration.Isnt it braking that heats the motors up a lot?
Amen to that!Getting to 140mph is a big deal These pros make it look easy. What James has done on that skinny road is amazing. Raz has the luxury of a private 4 lane runway with a gyro and it’s still very hard at that.
https://www.ebay.com/itm/333901619720Somebody needs to come out with a parachute.ive seen it on drag cars.but going 140+ kinda chute.could also double as OH $HIT BUTTON!!!!
