They are necessary unless you wanna try running yours with terrible geometry or risk running your turnbuckles with just a single thread ??✌?Looks really good!!
Quick question, are the turnbuckles necessary to run the Typhon arms are can you just run the arms and extend the turnbuckles?
Is the same true when you use the hotracing extended hubs? I’m thinking about converting my Senton into a big rock.They are necessary unless you wanna try running yours with terrible geometry or risk running your turnbuckles with just a single thread ??✌?
The hot racing extended hubs just go onto the threaded part of the driveshaft, they have nothing to do with turnbucklesIs the same true when you use the hotracing extended hubs? I’m thinking about converting my Senton into a big rock.
Nope. The HR extended hubs don’t affect a-arm width so turnbuckles are fine as is.Is the same true when you use the hotracing extended hubs? I’m thinking about converting my Senton into a big rock.
You should have some blue thread lock. It is not included but very necessary. ??Anything additional needed to complete this? Just typhon arms and turnbuckles and you're good?
On the little screw thing that holds the hex extenders in?Nope. The HR extended hubs don’t affect a-arm width so turnbuckles are fine as is.
I'm pretty sure you need the turnbuckles as they are longer than the ones for the bigrock. I don't think the bigrock turnbuckles will extend enough.Looks really good!!
On the black barrel nut that holds the hex on. Just a dab inside the threaded end before assembly. Too much and it will cake on everything else and make disassembly that much harder later.On the little screw thing that holds the hex extenders in?
