I just got the blx85 esc for my granite bls and for whatever reason it doesn't have much power going forward but has normal lipo power in reverse. I checked all setting that I know to check and I'm still stumped! Any recommendations?
Note: This feature currently requires accessing the site using the built-in Safari browser.
I had the same problem running my Castle Sidewinder 8th 2200kv system in my modded Backslash, swapping motor wires did the trick.Thanks. I actually do have the granite blx brushless as well so I'll try the bls esc on the blx and see what happens. I'm assuming if it works good on the blx then it's not an esc problem? If that's the case I'll try the motor leads idea and if that doesn't work then I'll be even more lost!
Wish I could be more helpful on this, just wondering if it would be worthwhile to get BLX motor too for better performance gains. Reread your post, didn't catch it was ESC only upgrade.Unusualrc I did the wire swap which worked so thank you but something is still off about this thing. It's not nearly as snappy as it was when the original esc was on it. It has a delay before it really starts going and it won't pick the front wheels off the ground anymore. The battery is brand new and freshly charged.
