RickTheSlick
- Kraton 6s
By specs it says 6.5mm in the ESC. But the other side of the cable has no connector at all..? Cant I use 4mm connector on that side or what?Aren't they 6.5 by the specs? So you need adapters, or change either the ESC or motor bullets.
I will read the manual, dude... I want to know what connectors I have to order......Just read the manual, dude. It has bare wires on the battery side and 6.5mm bullets molded in on the output side.
4mm. The motor wil draw the same amount of current than it would from the stock ESC so no need to beef up the connectors.I will read the manual, dude... I want to know what connectors I have to order......
Perfect. Thanks for answer. ??4mm. The motor wil draw the same amount of current than it would from the stock ESC so no need to beef up the connectors.
If you decide to put a bigger motor in that will pull more Amps, it’ll have bigger cable which will need bigger connectors.
Thanks pal. I did order 4mm bullet connectors, and couple of EC5 connectors. It'll be good, I hope. ?I run the max6 and blx2050kv in both my outcast and ERBEv2. Both of my max6's came with esc->motor cables that don't have ends on them for the motor. I just used 4mm to match what the blx2050kv had on it:
https://www.amazon.com/gp/product/B07BFV4HDQ
These came in the box with the esc's:
I'm not sure what size the ends are that plug into the esc. I just know they are the same size my MXL-6S (MMv2) and HPI F360C (MMv1) used as I didn't need them on my revo since I had already made adapters to the motor.
I can't recall what connector came on the input side as I replaced them with 2 XT90's to run 2x3S since that's what I ran before and what I have to run in 2 of my 6S trucks.
