thekersh86
Hey guys,
Some nice people on here helped me troubleshoot some issues I was having with a Mojave that led to getting a new ESC under warranty. Installed and calibrated it with no issues, but now seem to have some problems and it hasn’t left the bench. I’ll try not to be too long winded.
Trying to replace some motor fans that weren’t running anymore. Using a splitter from the programming cable on the ESC, hooked up the new fans and neither would run. May possibly be an issue with the adapter and splitter cables, I plan on trying to isolate that tomorrow. The issue is that now the ESC fan is not running. I tried two separate batteries that should’ve had more than enough charge. I remember the fan running when I originally installed the new ESC. It doesn’t budge at all, and the startup beeps informing of a 6s battery sound a little…off.
I know there’s a chance it’s a bad ESC from the factory, but is there anything I did wrong or can do right to possibly fix it? Any ideas appreciated.
Small detail, running a promodeler servo on its own 2s battery, could that have affected the original ESC and now be causing issues for this one?
Thanks again for all the help.
