dizzle000
Hey everyone so today I got a new granite blx a 5000 mah 6cell nimh battery (for my son) and a couple 5000mah 50c 2 s lipos. My question is I set the esc to nimh everything works fine when you have the transmitter set to 75% but when you turn it up to 100% and punch it, it will go hard then say you hit a hard turn and spin out and get on the throttle again it goes blah.... almost like it has 50% power I pulled the body off to check the esc lights and they seem to be blinking normal. So I turn the truck off and back on again and all is good until you do it again, is this low voltage cutoff, or is the esc trying to pull to much power from the nimh batteries and triggers a cut off? I haven’t tried it out yet with the 2 s battery to see if it does the same thing or not.
