rccar4life
- Limitless
- Kraton 8S
- Kraton EXB
- Mojave EXB
- Talion
- Typhon TLR
70 size , how to fit this in Arrma Kraton 8s ?
https://www.hobbywingdirect.com/products/ezrun-70125-motor
Look at the WEIGHT
lol
https://www.hobbywingdirect.com/collections/ezrun-max4-system/products/ezrun-max4-esc
O-M-G
Specification
Model | 70125SL-560KV |
PN | 30402850 |
Pole | 4 |
KV(No-load) | 560KV |
R. (Ω) | 0.0050 |
Current No-load(A) | 3.6 |
Motor D.&L(mm) | 70mm (2.760in) / 125mm (4.921in) |
Shaft D.&L of the projecting part(mm) | 8mm (0.315in) / 30mm (1.181in) |
LiPo(S) | 8-12S Lipo |
W (g) | 1995g |
Applicable | 1/4th, 1/5th Heavy-duty Off-road, Truck. |
Best match with | MAX 4 HV ESC |
Look at the WEIGHT
lol
BottomlineWorld's Largest : 1/4 - 1/5th MEGA RC vehicle
Off-Road, Truggy, and Monster
- The ESC uses a special process, coupled with an innovative waterproof design, to increase waterproofing and dust-proofing performance in different climates. It is easy to deal with the harsh conditions containing sediment, ice, snow, and water accumulation.
- Built-in ultra-powerful switch mode BEC with a continuous current of 10A, an instant 25A, and support for 6V/7.4V/8.4V switching, supporting a wide range of powerful and high-voltage servos.
- Equipped with the most advanced and safe electronic switches. The traditional mechanical switch protects and prevents dust, humid and other harsh environments, contact rust, and violent impact (such as flying slope landing)
caused by the automatic closure of mechanical switches and other issues. - Built-in fire-proof circuitry to protect the battery plug, while effectively avoiding damage to the case from electrical sparks (fingers).
- Multiple protection functions: battery low voltage protection, ESC and motor overheat protection, signal loss protection, and current protection.
- Support LED program card, LCD program box, OTA programmer (Note: optional) to set the parameters of the ESC.
- Real-time data recording function to view various running data on the HW LINK app using the OTA Bluetooth module.
MAX 4 (HV) | |
Scale Vehicles | 1/4 - 1/5th |
Cont./Peak Current | 300A/2000A |
Motor Mode | Sensored and sensorless brushless motor |
Input | 6-12S Lipo |
Motor Limit | With 12S Lipo: KV≤600 70125 size motor |
BEC Output | 6V / 7.4V / 8.4V adjustable, continuous current 10A (Switch-mode) |
Programming Port | Share with Fab interface |
Switch Mode | Electronic Switch |
Capacitor protection | Yes |
Waterproof | Yes |
Size (L.W.H) mm | 125 x 85 x 61.7mm |
Weight (g) | 775.4g |
Motor recommendation
HEHEHEO-M-G
