Here’s my idea helpsOk so after like four broken wings and mounts, I decided to combine a couple ideas I have seen on here. Here is the finished oroduct
Steel my tig welder took a dump so working with steel for now it ties in to my shock tower braces that I madeHmm I like that I might give it a try Is that aluminum or steel?
Nice mod.......... Seems like you’re coming around with Wing Mounts.Pretty happy with this mod. Prevented my wingmounts from snapping.
After bad landing:
Simple snap back in place:
I mounted them to the tbone block on the bottom, drilled and tapped M3 holes. Wing screw holes supported with custom alu plates but now moved to washers to spread the load a little.
Using M3 stainless steel threaded rod from Amazon, a lot cheaper. I bought 110mm long but trimmed to 100mm.
