Infraction New Infraction 3s, what to do?
Denmark
  1. Infraction
  2. Limitless
  3. Kraton EXB
I just got a Infraction 3s, first time on a plastic Arrma, i always been on the 6s line
What do you guys look after on it, do the diff need olie like the 6s line 🤣
What to upgrade, beside a front splitter, maybe a carbon rear wing
Do they hold up for more power, 4s or 6s
Here's my
Congrats on your 1st 3s! 😁
Yes, as always check the diff oil. Other upgrades OTB are the same as 6s.....bearings, servo, a center driveshaft support helps if going to 4s.
I purchased the Mega version and turned it into a 4s. The 3s drive train can handle 4s, but I do not believe it will on 6s without some major upgrades.
Happy Bashing!! 😁✌️
Happy Bashing!! 😁✌️
Thanks 🙏
Yeah was thinking a better servo and ESC for a start , do you have any link for the center driveshaft support?
So 6s is not a good idea 😁
Yup, should swap right out. I forgot the 3s comes with the plastic one, my bad. I had the Mega.
I also upgraded the plastic driveshaft to aluminum. If you get the HR one, you will need their center drive support bearing.
Get a center brace too. I got a CF one from ramjam racing. It was specifically for the mega though, so make sure to check the length for the 3s, not sure if it's the same.
Here's what I have done to my Infraction 3s:
R6F receiver for Radiolink RC6GS radio system
Spektrum S652 servo (had laying around)
Hoons white label wheels and tires
Arrma CNC steel-geared transmission assembly, front and rear
Hot Racing aluminum diff yokes, front and rear
Aluminum center driveshaft
Carbon fiber tower-to-tower chassis brace
Carbon fiber front splitter and rear winglets
3D printed aero chassis panels
GNSS GPS mount
A lot of what I have done is for durability, and other items are just for appearance.
Yes, I did this too. I think I got the idea from you! (y) 😁 ✌️
Just ordered a hot racing center shaft and bearings for it 😁
And also ordered a radiolink r6f, already on the radiolink so that's easy 😊
Also ordered those CNC metal gears for front and rear
Thanks guys for all the help 🤠
View attachment 270569View attachment 270570
Is there no long wheel base driveshaft? I'm supprised the short one worked.
