brandonyoungbar
My limitless arrives tomorrow, any suggestions on the combo I should put in it. I’m thinking max 5 with the 800kv motor.
First speed run car, I have a infraction for a parking lot basher. Do you suggest a different motor? I planned on trying to get comfortable doing 100mph passes before doing anything to crazyHow do you intend to run it?
Parking lot basher geared under 90 or speed runs 100+?
I appreciate the feedback and the information. I’ll take a look at the buildlogsThe max5 will limit your max rpm/amp draw, which won't get you past ~120mph
A 2028 is a very big can (and the 800kv quite low in terms of finding matching gearing)
If you want to keep the stock battery/motor configuration, you are restricted to a max motor length of ~90 mm, like a CC1717 or TP4050. Reversing the motor mount gives you all the motor space you can wish, but needs some battery placement adjustment.
I'd suggest to look at the buildlogs of the many limitless owners here, and chose a path that suits you
