Porschetech🇬🇪
South London hooligan Living in Cali
- Hayward, California
- Felony
- Infraction
- Limitless
- Kraton 8S
Oh.....I thought 80 mph was only possible with the higher speed pinion. It’s kind of poopy when you mod for more speed and you end up with less than stockHe was probably using the speed pinion, 27t. I actually have not used it yet. I got a top speed of 65 mph with a 20tP/50tS on stock, so I was trying to see what just the motor change would gain. Then the ESC or batteries issue came into play last weekend when testing. I also figured I'd do the one at a time pinion change with the newer motor. Knowing it was 150kv more then stock, I didn't want to burn it up first couple outings. I may pop the BLX185 back in but I need wire converters from a 6.5mm size back to a 4mm for the new motor to do that...
