Hi Everyone - just got a Mojave EXB and have some questions. Sorry, I'm new to large scale RC - so please go easy
1) Since I have to add electronics I was looking at putting in the Hobbywing Max 6 with Hobbywing 4985/1650KV.
a) How does this compare to the stock BLX ESC and stock motor on the non EXB Mojave?
b) Will I get more torque/speed with this setup?
c) Is there a better option than the Hobbywing motor to pair with the Max 6?
d) Do I need to use a heat sync/fan on the motor?
2) Will the Max 6 fit on the ESC mount supplied with the EXB or do I need to get something like the M2C ESC plate?
3) Is there info somewhere on how to determine what tooth pinion to use? My EXB came with a 16 tooth pinion with a yellow warning card stating to run "high speed gearing" on hard flat surfaces only and to not run off road. Ummm, what?? It's all a bit confusing to me..
4) How about servos? I know there are a ton out there. I was looking at Reefs - but not sure if I need/want to spend $100 on a high end one.. Any decent for about half the cost?
Thanks for any info you can help out with! Looking forward to bashing this beast!
