Jexz
- Kraton 8S
- Kraton 6s
- Notorious
- Outcast 6s
Hi guys,
i just received my PPS motor mount, and now i'm going to get a new motor, i will take the 800KV but i wonder if you guys can help me with the gear ratio.
For the moment i will keep the stock ESC, is it worth to change only the motor and keep stock ESC?
About gear ratio i don't want to do speed run i just want decent speed, actually i run with a 19t pinion and thats sufficient for me, what pinion do you recomand me to get aproximatively the same speed?
Do i need to change the stock spool? What do i need to replace the stock spool with the Limitless spool, do i need some others parts?
Thanks to you guys
Thanks to you guys
