TraverseCity420
Total Arrma Fanboy
- Thread starter
- #101
How much torque does the notorious stock servo have?
Not enough lol
I use a savox 1210sg it’s a direct. I did have to add a spacer on the arm not sure what it’s calledI think I will try a savox but I don't know which fits the best with out mods. Does any one know i don't have not done this before need a little help please . I know guys use them.
The monsters are tall don't know if they will work with out mods.
You can definitely make one I did out of some plastic piece. I don’t know how many amps it pullsWhere did you get the spacer WTF MIKE. Can I just make one THANHS FOR THE INFRO THAT HELPS. Do you know how many amps it pulls? Some say the power hd 20kg will do pretty good much cheaper. Cheaper not always better LOL.
THANKSYou can definitely make one I did out of some plastic piece. I don’t know how many amps it pulls
THANKS WTF
On my outcast, I had to use 3mm longer screws and 4-5 washers under each corner to raise it up or the servo would hit the chassis before the screws were tight.I use a savox 1210sg it’s a direct. I did have to add a spacer on the arm not sure what it’s called
That’s weird I didn’t have to raise the servo I even have room to run the wire underneath itOn my outcast, I had to use 3mm longer screws and 4-5 washers under each corner to raise it up or the servo would hit the chassis before the screws were tight.
If I had been thinking, I would have put them under the servo mount itself instead of between the servo and the mount, as that was a total PITA. Using some 2mm spacers probably would have been enough.
You can kind of see them here:
Yeah, with the 3 or 4 washers on each corner, I have enough room to slide a piece of paper under the servo, but that's about it. Mine is the 2018 outcast.That’s weird I didn’t have to raise the servo I even have room to run the wire underneath it
