catspajamas
- Outcast 4s
hi everyone
So i just got my first Arrma RC A outcast 4s
Here is how my first run went .
I went out with 2 fully charged and balanced 2s lipos 5000mah 60c
I was running the truck on a huge asphalt parking lot back n forth getting use to it..
I went for about 3-4 minutes having a great time ...... then the truck stopped
The truck would steer but no forward or reverse..
The esc was blinking red.. so i felt the esc to check the temperature .. it was completely cold.. no trace of any heat. i assumed the truck had just eaten all the battery juice. but i didn't bring my battery voltage checker with me.
i turned it off for 5 minutes and back on .. same thing .. no forward or reverse.. steering yes
i drove home.. tested when I got home about 15 minute drive.. same thing.. no forward or reverse
this was a cool day .. flat asphalt. the truck hasn't even see dirt yet or done a single jump .. all fans working
when i got home tested my batteries. i had honestly though the RC must have just run the batteries dead.. but all cells tested were sitting at 3.84v
1 day later I put the same batteries in . I left them at the same 3.84 volt because that storage voltage
and the RC works. forward reverse and steering.
so what's going on here? bad esc ?
is the truck supposed to thermal after 4 minutes on flat asphalt ?
i also did all proper start up calibration to the truck
if someone could give me some info on running time and conditions
or is this just all bad luck here with a brand new RC?
Thanks
Thanks
