Outcast New Servo - Hitec D980TW
sgerbitz
  1. Fazon
  2. Fury
  3. Granite
  4. Nero
  5. Raider
  6. Senton 6s
  7. Talion
I am thinking of getting the Hitec D980TW servo, would this be overkill?
Special Features:
- Wide Voltage Range: DC 3.5-8.4V
- 2 cell Li-Pi (6 cell Ni-MH) compatible
- Programmable digital amplifier with MOSFET drive
- Gold plated connector
- Narrow dead band width & high standing torque
- Applied H25T horn gear
- 3mm horn screw (‘+’ & HEX socket screw included)
- 32bit MCU / 12bit ADC
- Durable titanium alloy metal gears with dual ball bearings
- Ultra hardness gear shaft with 3 axial metal bushing
- Heat sink for motor
- Water & dust resistant (splash proof)
Dimensions 1.72” x 0.88” x 1.57” (43.8 x 22.4 x 40mm )
Product Weight 2.76oz (78.2g)
Output Shaft Style 25 tooth (H25T) spline
Voltage Range 3.5V - 8.4V
No-Load Speed (4.8V) 0.28 sec/60°
No-Load Speed (6.0V) 0.21 sec/60°
No-Load Speed (7.4V) 0.17 sec/60°
Stall Torque (4.8V) 361 oz/in. (26.0 kg.cm)
Stall Torque (6.0V) 500 oz/in. (36.0 kg.cm)
Stall Torque (7.4V) 611 oz/in. (44.0 kg.cm)
Max PWM Signal Range (Standard) 750-2250μsec
Travel per µs (out of box) .080°/μsec
Max Travel (out of box) 120.5°
Pulse Amplitude 3-5V
Operating Temperature -20°C to +60°C
Continuous Rotation Modifiable Yes
Direction w/ Increasing PWM Signal Clockwise
Deadband Width 2µs
Motor Type Coreless
Feedback Style 5KΩ Potentiometer
Output Shaft Support Dual Ball Bearings
Gear Type Straight Cut Spur
Gear Material Titanium
Wire Length 11.81" (300mm)
That servo seems slow but strong probably good in a crawler... i was testing my new HD lw-20mg waterproof servo today very impressed with it,I'm a newbie to rc's an even I noticed a big difference from the stock arrma servo and it was about £25 from Ali express,bang good also sell them but are out of stock. Or you could just gt a savox or hitec for about 3X the price
