OutcastKB
I just put a new servo in my Outcast 6s EXB ready to run. Replaced the stock one because it just stopped working. The new one will only turn one direction, I turn right it turns left, if I turn left it turns left???? I switched the ESC and servo plugs in the receiver and the throttle will turn the servo one direction and the brake turns it the other so I am assuming it is something in the transmitter settings. I have already reset the transmitter to factory settings and bound it again no change. I even went to try and set end points and it would not respond at all when I had the transmitter in that mode. Any thoughts?
