All personal preference. I'm running 70wt in my BR and Granite. Both rigs are upgraded with 4s systems and Typhon 6s shocks though.i am sorry it was 45 wt. oil
Not necessarily, depends on what kind of bashing you're doing. I go heavy because I was launching my rigs at skate parks and off a ramp. You might just need to add the pre-load spacers.ok but should i be running heavier weight to stop the sagging
Try to add some more spring preload first. I guess the sagging makes you think the shocks are too soft while are not.ok but should i be running heavier weight to stop the sagging
Not sure if that solves the problem. More springload raises the ride height of the truck but doesn't make the spring harder. If you want a harder suspension, use a harder spring. My statement is based on the use of springs in RC Touring Cars and is common knowledge there. Can't imagine it to be different in Monster Trucks.Try to add some more spring preload first.
There are progressive springs that progressively stiffen when compressed. What happens when you change the ride height is that the piston in the shock changes its position. When the droop is at maximum, the piston has more oil above it to push through and dampens more, and viceversa.But by adding preload, you also get the spring into a stiffer part of its rate (springs are never 100% linear)
I ran 80wt shock oil, Tekno orange springs on Typhon 6s shocks in my Granite and it was still chassis slapping at the skate parks.For what it's worth... but since I did wrote something about a video... here it is
I use the Arrma 80mm rear springs in the front. And the new 90mm springs in the rear.
So a bit softer in the front, I believe that is good for the steering.
But if this setup is to stiff... time will tell.
I am also using 1000 cst = 80wt shock oil.
Need some test driving outdoor... and some better weather.
Note, also Hot Racing has some springs for Arrma Big Rock. More expensive but you get 3 different stiffnes (wire diameter), also 90mm.
Shock oil thin or thick does not make a shock SAG. Oil does not affect spring height at all. Springs do. Maybe you need to adjust shock preload better. What is shock preload??? Learn about shocks. There are many many videos about them.ok but should i be running heavier weight to stop the sagging
I kept breaking front stock hubs, replaced with HR and the pins kept popping outta my rpm arms. I hear ya!I believe that is ok. Some chassis slapping when jumping high and hard there should always be. If not something else will break.
If the shocks where replaced by a solid iron-rod then the suspension arms, shock towers or something else would break.
Something always break when driving hard, I am just trying to find a setup so the right parts breaks. The small cheap parts.
I am not driving/bashing that hard yet...
Hi. Do you know that are these same springs but just set of 4:For what it's worth... but since I did wrote something about a video... here it is
Thanks. Ordered those ones. See how it works because I also thinks that Big Rock suspension is quit loose.p00kaju, yes they are.
