If the screw has sthreadlock it should nit back out at all. Stock set up of the 4s clutch is 1.25 turn from fully tight take your time when you remove the screw the first time its a bit difficultView attachment 73423
So I've got the new parts all installed. Does the 4s slipper clutch need to adjusted before I run it? I can't get it to budge. What does it do and does it get looser running it?
Is it ok to run it with it right?If the screw has sthreadlock it should nit back out at all. Stock set up of the 4s clutch is 1.25 turn from fully tight take your time when you remove the screw the first time its a bit difficult
If the car become incontrolable or agressive your slipper is too tight you will know when its too tight or too looseIs it ok to run it with it right?
