BLX New to the sport
Discussion in 'Kraton' started by Reaper007, Jul 7, 2018.
  1. Reaper007
    Reaper007 Active Member
    Apr 22, 2018
    14
    7
    Arrma RC's:
    Kraton
    Just got my very first rc..and i have no idea what I'm doing..i guess it's a learn as you go thing..that's fine with all the help from the forum i should be fine..so let's start with this..what do i need to do before her very first run..
    Jerry-rigged likes this.
  2. Krick
    Krick Active Member
    Jun 29, 2018
    1
    Arrma RC's:
    Kraton
    Break her in gently right out the gate whether it's stock or adding mods.
    I plan on changing the differential oil 60/200/30, making sure everything is meshed up, I may shim when switching to 6s or do it now, making sure all the screws are tightened, new servor, backflip tires with holes in tires and filling in wheel's holes, adding new rpm bumpers, skid plate, rear wide basher plate, may boil wing mount, HR aluminum chassis braces, mud guards, taping the inside of the body shell and holes up, taping batteries, thinking about plasti dipping underneath the chassis and roof, and turning down the punch and brake force (75%), raising the cut-off threshold to 3.4 with my hobby wing card during the break in period. And even adding paddle tires and protective cover to keep the sand out when hitting the beach.
    When it's time for 6s I'm going to blast it and bash it, may get a 13t robinson pinion so I don't have to worry about heat issues as well. Whatever you decide to do just go out there and have fun.
  3. Reaper007
    Apr 22, 2018
    14
    7
    Arrma RC's:
    Kraton
    Thanks for the info..definitely need to check all screws..but why turn down the punch and brake..and is that only during break in..i have diff shims and bearing for it should i install them now or wait until i need to replace them..
  4. Krick
    Krick Active Member
    Jun 29, 2018
    1
    Arrma RC's:
    Kraton
    I just turn down the punch and the brake during the first battery or two during the break in period, it's not a necessity. Some people change the diff oil the very first day, and if you're in there you might as well shim it too or vice versa, but if you're just going running 4s it's not necessary either. I'd only change the bearings when needed, you can always clean them up and lub the old ones to get more life out of them after a hard run.
    #4 Krick, Jul 8, 2018
  5. Reaper007
    Apr 22, 2018
    14
    7
    Arrma RC's:
    Kraton
    Great..i think I'll run it a pack or two then I'll do my diffs..that way if i screw it up I'll have a couple runs in.. How difficult are they to disassemble and reassemble..what tools do i need to get started..
  6. Krick
    Krick Active Member
    Jun 29, 2018
    1
    Arrma RC's:
    Kraton
    #6 Krick, Jul 8, 2018
  7. joostin420
    joostin420 Well-Known Member
    Sep 21, 2017
    302
    197
    MA/NH
    Arrma RC's:
    Fazon, Kraton, Nero, Outcast
    never drive it until it’s fully built :D
    Welcome to the addiction :greedy:
  8. Krick
    Krick Active Member
    Jun 29, 2018
    1
    Arrma RC's:
    Kraton
    I agree, as hard as it is to be patient, part of the fun is building it right the first time so you have less problems and more fun in the future.
    joostin420 likes this.
  9. Jerry-rigged
    Jerry-rigged Premium Member!
    Premium Member Excellence Award
    Apr 27, 2016
    1,822
    997
    Texas, Baby!
    Arrma RC's:
    Kraton, Typhon, 4x4-Mega
    I'd rather drive it and build it up as it breaks. She'll tell you what needs upgrading, and when... LOL :D
    Dlostradamus and DaleP like this.
  10. DaleP
    DaleP Well-Known Member
    Apr 11, 2018
    36
    14
    Arrma RC's:
    Kraton, Senton, Typhon
    Yup, I broke my Typhon in on the track.
  11. dpricenator
    dpricenator Premium Member!
    Oct 25, 2016
    1,145
    934
    Arrma RC's:
    Kraton
    Read this forum all of it. There is more info here than anywhere on the web. When you break something upgrade it. Not a bad idea to buy extra parts so you don't have to wait during a parts shortage.
    ThatDrewGuy likes this.
  12. Reaper007
    Apr 22, 2018
    14
    7
    Arrma RC's:
    Kraton
    Just took my kraton out for the first time yesterday and i ran into a wall at full speed.i pop the pillow ball out and bent the shock tower..pop the pillow ball back into place and went back out this morning..ran a pack and a half then i found a pretty nice mound were i can get some good height in my local park just to have the esc fill with debris and shut down..so i cut my time short came home and could not wait to give you my opinion..WOW..i had such a good time blasting around my local park..they cut the grass a couple of days ago so there's a lot of dry grass everywhere which eventually clogged my esc and shut down the vehicle..so now i have to take the esc apart..clean it out..take the shock tower apart straighten it out put it all back together and i have not been this excited since i was in high school building hotrods with my buddies..now i get to tear her down and clean her up and rebuild her..WOW again I'm in heaven..this is what it's all about..BLAST IT BUILD IT ..BLAST IT AGAIN
    Jerry-rigged, xSUBtRONiKx and Brandon like this.
  13. xSUBtRONiKx
    xSUBtRONiKx Well-Known Member
    Jul 11, 2016
    27
    11
    A-town
    Arrma RC's:
    Kraton
    If you put some sort of mesh or screen above your ESC fan it will keep debris out. I was always getting mulch in mine which would stop the fan. The Voltage Hobbies shock towers are the best upgrade I have ever done. They are machined from 7075 aluminum and tough as nails. I haven't bent mine yet and its been almost a year of hard bashing!
  14. Rgcuban
    Rgcuban Active Member
    Apr 11, 2018
    Arrma RC's:
    Typhon
    What a good aftermarket body for Kraton???
  • Welcome to Arrma Forum
  • Disclaimer
