Kg77
- Echo bay Ontario Canada
- Granite
- Infraction
- Kraton 8S
- Kraton 6s
- Notorious
New toy pretty pumped!!
Care to elaborate? They literally share the electronics and drivetrain... Should be almost the same if gearing and diff oils are equal.Hell ya! I can’t get over the power difference compared to kraton 8s so much better!! What a blast to drive
I was told different programming but not 100 percent sure but it’s very noticeable difference from my kraton! I might try installing the esc outta kraton just to compare. Without a doubt they did something differentCare to elaborate? They literally share the electronics and drivetrain... Should be almost the same if gearing and diff oils are equal.
So much nicer without wood paneling!!!I was told different programming but not 100 percent sure but it’s very noticeable difference from my kraton! I might try installing the esc outta kraton just to compare. Without a doubt they did something different
Front bumper is a winner! Might have to get one for the kratonView attachment 106400View attachment 106401
Yeah it has the punch set to 5 and 20million diff oil in the center, not sure about the pinion. Glad you enjoy your truck!I was told different programming but not 100 percent sure but it’s very noticeable difference from my kraton! I might try installing the esc outta kraton just to compare. Without a doubt they did something different
The punch came set to 3 but the center diff has 20 million, also I’m pretty sure they changed something in the esc if I understood rich duperbash correctlyYeah it has the punch set to 5 and 20million diff oil in the center, not sure about the pinion. Glad you enjoy your truck!
