New Typhon Progress.
LordChaos
Washington USA
Hey Guys,
Just wanted to start a thread showing off the newest addition to my Arrma Garage.
Here is a brief rundown of whats been done prior to it's maiden run.
  • Complete tear down
  • Bulletproofing for all three diffs
  • Fast Eddy bearing kit
  • Hobbywing Max8 combo
  • Associated hex extenders
  • Voltage Hobbies Chassis braces, servo mount and steering rack
  • Tekno 18t pinion
  • Cut down a stock motor mount to make the front diff brace
  • T-Bone front and rear bumpers
  • Stole the Yeah racing fan/heatsink from my outcast
  • Fiberglass tape+E6000+bedliner inside the body
  • Grabbed a set of Duratrax Lockups to test cause they were cheap (not pictured)
During teardown I discovered the car was not in terrible shape and the rtr crew did a mostly ok job. Here are a few things of note from that process.
  • Several loose screws
  • A couple over-tightened screws resulting in stripped plastic threads
  • Over use of lock-tite substance in several areas, front bearing on the rear diff case was caked full of it
  • Mostly empty front diff
  • 1 shock low on oil
I'll just say that there was enough wrong to make the teardown worth the effort but not so much wrong that I feel Arrma got rid of their quality control team. Also a huge shoutout to M.I.P for taking a lot of frustration out of the teardown/rebuild process. Cant stress enough the importance of a good set of hex drivers.
I am sure I will think of more later but here is the initial list of things I want to get done to it in the short term.
  • High voltage capable receiver
  • Savox 1210sg
  • The rest of the things Voltage Hobbies makes for this buggy
  • probably a new motor depending on how the hobbywing does
  • probably some suspension changes
  • Proline MX 28's
Here is a couple more pics to look at while I go drive it for the first time :) thanks for reading.
Thats just the small cap pack that came with the max8 combo. Figured I would wire it in until I get a better one. Not at home right now but I think Killmode rc or something like that is making some top notch cap packs.
