- Tel Aviv, Israel
- Granite
- Senton 3s
- Talion
- Typhon 6s
- Typhon 3s
- Voltage
Lets seeWant a list I’ll give you a list (not in any particular order)
- Fix the leaky shocks
- seal the slipper housing
- change the motor to a one with bearing that actually hold
- slightly longer shocks
- droop screws, to avoid stripping the shock rod ends
- body support brace like they have on the 6s/8s, which will also replace the flimsy center driveshaft bearing support part
- option for center diff
- rotate the servo like on the 8s so it won’t get jammed by rocks
- metal pivot balls
- fix the Senton front bumper
- vented tires from the factory
- Yes
- Not totaly sealed, but they say it's much better
- The motor is different, i'll give them the benefit of the doubt
- nope
- nope
- nope
- nope
- It wasnt rotated, but they say the new bell crank addresses that
- nope, maybe the plastic is better?
- nope!
- yes!
Adjustable motor mount
Sealed bearings.... actually that’s for all models and a good Rx
Sealed Bearings
Quicker TX/RX
Improved shock seals
Well i guess they listen and improve after allSealed transmission case
Redesigned steering rack so rocks don't jam it up
Better tolerances on the motor mount holes
Sealed bearings
Better radio
