Please forgive me, first time really getting into the diffs on my Granite BLX 3s and have some questions. I got a set of the Fast Eddy sealed bearings when I noticed that one of the wheel bearings had basically exploded. I replaced all the wheel and axle bearings, and now getting into the ones in the diff. A few questions as I'm working on that, see the picture below for clarification to match what I'm talking about with question # since I'm not sure the proper name for everything...
1. Is there a trick to getting this bearing off? This one seems to be on there %^$@ing tight! I got it off the rear diff only after I exploded the thing trying to pull it with some channel locks. I can pry it a couple millimeters by getting a flat screw driver between the bearing and the gear side, but haven't found a good way to get it off the rest of the way.
2. This washer, I don't seem to have it under the bearing(s?) that fits into the yoke set. I replaced both of those bearings and didn't see a washer under either one of them. Based on the picture, am I seeing correctly that it is just supposed to be on the one side? Do I need to order and put one in? I honestly can't really tell what it would be needed for there unless it's just to prevent rubbing?
-- Speaking of the yokes, is there a right and wrong side for these to go on? I can't seem to tell much difference in the 2 sides and trying to make sure I have them back on right.
3. I assume the grease in these gears is where I want something like what is labeled "diff grease"? Is there a specific requirement for this grease? I only ask because I happen to have some of the Lucas red n tacky (and some other greases from non RC use) that there is a current thread on being a high quality grease. Would a bit of that work here or do I need something different?
Thanks for helping out a new guy!
