chocwheaton
- Infraction
- Kraton 6s
Hi all,
Got my Kraton v5 late yesterday afternoon. Amazing looking machine!
Read up on things to check before taking it on its first run:
Then the second 6S lipo. Did some 100% throttle as well. Not she wheelies, and some high speed runs on the field. Wow!
Then did a little driving in the car park...some more wheelies...and...what's that noise? Better stop.
I only ran it for a few seconds with the noise. Did an inspection and couldn't see any issues with my untrained eye taking a look over it.
I thought at first it was something in the front diff as it sounded like it was coming from there, so I headed home, took out the front diff (thanks google), inspected the gears and it all looks good. Re-assembled it thinking I got lucky and it'd be good now. I took it out again at lunch time, and as soon as I applied some power, it makes a grinding noise. Dammit! Why me!! Ha ha.
So I call my local hobby shop which is about 10 minutes drive away, and he has time to take a look this afternoon.
I head straight there, hoping it'll be an easy fix and I can go for another drive today.
The guy is super helpful, takes a look, and see's that the centre diff case is cracked and leaking oil. Hmmm...I missed that little issue.
One thing I like already about RC cars is how cheap parts are! So for about $30 in parts and the same in labour, they are going to sort it all for me. I considered doing it myself, but for $30 in labour for him to do it, I won't try this time..
I just have to wait 24 hours before another drive.
The guy at the shop said that driving on high traction bitumen surface is really hard on diffs, especially if you're doing wheelies. Arrrhhh...yeap that's what I was doing. My bad.
I guess I thought that if these cars can take big jumps and hits like on all those youtube vids, it'd have no trouble hooning around in a car park. I stand corrected. I was also probably very 'ham fisted' on the throttle and not driving smoothly either, due to in experience which would have contributed to over loading the diff.
The upside is I taught myself how to take out and install the front diff, and how to remove the motor, and adjust the mesh on the motor pinion and centre diff with a piece of paper. And now I know to take it more easy on bitumen.
I guess the fun learning has started
Cheers
- Checked gear mesh (as best as I could without actually knowing what I'm doing )
- Set steering dual rates- did make some minor adjustments
- Checked all bolts were tight - one wheel nut was quite loose out of the box
- Zip tied a few cables out of the way
- Added a foam pad for the lipo tray
Cheers
