ArrmaGraniteState603
- Granite
Hey Guys,
Glad to have this resource here. Picked up my Arrma Granite 3S BLX a couple days ago and have had some awesome runs with it, I did have to replace the spur gear and the slipper clutch so far. Found how to tighten the slipper clutch and all seems to be well there. Couple questions I've come across since I've had it taken apart.
1. I've replaced MOST bearings with rubber sealed bearings. I couldn't get the driveshaft off either diff to access those but have replace most other ones, slipper clutch bearings included.
-That won't be an issue right, having two different types of bearings? Everything is symmetrical in that sense but just want to make sure that won't cause any unnecessary resistance that might put strain somewhere else.
- Is it recommended to lube the bearings? I heard no because dirt is more apt to stick to them. If yes, what do you use to lube?
2. Whats up with these shocks, seem to be adjustable maybe with that little tab on the top, is that possible?
3. I've had both diffs apart, I took as much of the old grease out and applied the recommended red and tacky in there. My question is how much do you use? Obviously don't want to gunk it up too much but want proper lubrication. It seems to be fine for now, maybe ill check it after a couple runs and give you a picture.
4. Does anyone have the Integy Wheelie bar? Is it a little bit longer, this thing loves to pop the front end up and I think a longer wheel bar might help that.
5. General maintenance? I try to clean it after each run, removing parts is a pain in the but when everything is dirty, especially that pesky power module.
6. Any recommended upgrades for durability? Already plan on the RPM A Arms based on what I've seen here.
7. Any tuning setting you'd recommend, as far as ESC, Punch setting, Brake Strength.
I have already done the throttle point reset. We mainly bash but every now and again like to race around, were mainly in dirt,sand.
Thanks ?
Thanks ?
