I almost learned the hard way why you need to get the wheels off the floor on a TX check. I had the Kraton on the garage floor and plugged it up to check TX and servo channels. I applied forward throttle and nothing happened. I tried reverse and it jerked forward. I noticed the throttle trim was off. I adjusted it the wrong way and all of a sudden it takes off in reverse and slams into my garage door and lost power. I hadn't secured the battery so the impact ejected it and it disconnected, thankfully.
I have a bent garage door panel but the kraton is ok
Got the wheels off the floor and found the throttle channel needed reversed and the trim adjusted. Way to go factory check.
