NiMH
celh
Hello friends, I'm new to this and I'm starting with a fury, I have a battery
How to make the first charge of my battery Duratrax Onyx NiMH 6C 7.2V 3000mAh buy a charger nano hitec and I do not know which parameters or what time to place for the load
Hi celh, which of the nano tech chargers you have?
If it is the X1 Nano you should do this:
NiMH BATTERIES:
  1. Slide the Charge Current Switch to 3A. (This will give you a recommended 1C rate charge)
  2. Connect the battery’s main power connector to the charge lead that is plugged into the main charge outputs on the front of the charger.
  3. Press and hold the BATT TYPE button for two seconds. The charge status LED will glow in a color according to the “Charge Status Indicator Chart” indicating that the battery is charging.
  4. When the battery is fully charged, the charge status LED will glow a constant green. Unplug the battery from the charger and the charge status LED will flash green which indicates the charger is ready to charge another battery.
Charge Status Indicator Chart:
LED green and red blinking The charger is ready to charge
LED glows constant red Battery capacity is less that 25% charged
LED blinking red Battery capacity is between 25% and 50% charged
LED glows constant yellow Battery capacity is between 50% and 75% charged
LED blinking green Battery capacity is between 75% and 99% charged
LED glows constant green Battery is fully charged
