so I'm kind of at a loss. My brcc used to do hella wheelies, but now I can hardly get it off the ground. It still has all the speed before but not the wheelies. A y ideas on the possible cause of this. Or am I just being retarded again
Did you change diff fluids?so I'm kind of at a loss. My brcc used to do hella wheelies, but now I can hardly get it off the ground. It still has all the speed before but not the wheelies. A y ideas on the possible cause of this. Or am I just being retarded again
I didn't even think of that lolRecalibrate maybe? That seems to do it for other vehicles. I also agree that changing fluids also changes things.
And no I haven't change any fluid in this one at all. Thanks guysDid you change diff fluids?
I did 60/500/30 2200kv i cant pop wheelie for nothing
Yeah that was actually the first thing I did was tighten a touch but not much difference really. I got. Whole new assembly I could stick on there Nd see maybe that is the problem. Also I'm trying to change my pinion but that sob won't budge. Suggestions on how to maybe get that fiddlestick off??Slipper loosened???? Maybe just tighten up a bit.
It happens with use. Need new slipper pads maybe. They get worn and glazed , especially when they get wet and dirty,
Slipper pads are a consumable item. FWIW.
.Yeah that was actually the first thing I did was tighten a touch but not much difference really. I got. Whole new assembly I could stick on there Nd see maybe that is the problem. Also I'm trying to change my pinion but that sob won't budge. Suggestions on how to maybe get that fiddlestick off??
If only I had one hahaha
It's not the grub because I can get that little thing out. The pinion just won't pull off the shift. First time I've ever tried to take It off too. And the eclip is off and grub screw is out.If the pinion is stuck and the grub is off. Use heat. Maybe some rust buster or equivelent. If you got the motro out, make sure to lube the bearings while your there. Look the motor over. Just a tip. Pry or use a puller of sorts carefully. If its the grub thats stuck. heat also and a quality Hex driver for sure. You may know this already.
This is a old dead thread your responded toHi, I just changed from 15t to 17t. That will make BR stay on track and donĀ“t do wheelies anymore??.
