So I recently did a servo fix on my kraton 4s and now it's barley reversing (it will reverse every once in a while when I throttle backwards repitidly) and occasionally it will crawl on reverse.
I didn't adjust anything I just centered the cervoYou could try following the throttle calibration procedure in the manual. I have also found that reverse is impossible with the throttle set at 50 or 75% since the esc never registers full brakes being applied. Did you change the throttle rate instead of steering rate when setting the new servo end points?
