roondog
Took senton out and noticed I have no reverse. Only changes I made recently was putting a new servo in. Did a quick search of forums but did not find anything helpful. Any suggestions?
It's the BLX. I'll check the manual just found it strange it would change.Well I mean I can tell by your profile pic it’s not a senton 6s but I can’t tell if it’s mega or blx. (Not your fault)
Many esc’s I’ve had usually lose reverse when they’re on their last legs. You should reprogram reverse in (if that’s possible per the manuals) and see if that fixes it.
Yep that worked. Feel like an uber noob. Thanks. The esc was flashing red but after the throttle change it stopped. Does that particularly mean anything?Most chances you touched the throttle trim dial on your remote? turn it till the truck will drive forwards by itself, then dial back until it just stops again.
Just did the same thing as OP. Thank you.Most chances you touched the throttle trim dial on your remote? turn it till the truck will drive forwards by itself, then dial back until it just stops again.
