Notorious No steering response.
Damn, ok switch the servo over to channel 2 and the servo should work with the throttle trigger instead. If that doesn't make the servo work then maybe it burned out? Did you set your endpoints prior to running your rig?
Endpoints uhh no.
Guys how do I set the end points on the slt3? The video you sent earlier doesn’t work.
Unfortunately I don't have that radio. Do you have the manual for it by chance? I'll check youtube to see if there's a how to video
Seems like there is no video on setting up a slt3, maybe someone who has that radio can help and chime in soon?
It’s an over two year old thread so you may not get an answer. However, often the issue is simply that the servo died.
