Yes three wires are right tried to bind controller to receiver but still only have steering I even tried to program the throttle and the red flashes don't even come up to do thatAre the 3 wires to the motor plugged in tight?
I Tried to adjust the throttle trim on the transmitter and nothingCheck your throttle trim first.. . Easy to knock out of whack
Bugga... My typhons done that a few times.I Tried to adjust the throttle trim on the transmitter and nothing
Yes fan comes onBugga... My typhons done that a few times.
Does the fan come on?? Ive had a glitchy fan that stopped the car going too... Unplug and try maybe?
You get it going???Thanks for all your guys help
No didn't get it going . Gotta call warranty department here in a little bit . I bought it on lineYou get it going???
With anything electrical like that i usually pull out all the plugs... Motor, servo, fan etc.. give them a blow out and put it back together just to be sure its not a simple bit of dirt in somewhere?
Hopefully its an easy fix and not a buggered esc... Did you buy online or at a shop?
Bugga... Hopefully they know what it is or send you a new one asap. No fun having a car that doesn't go :-/No didn't get it going . Gotta call warranty department here in a little bit . I bought it on line
tried doing a reset on esc won't let us do a reset tried doing reset on throttle won't let us do that either thank you for all your helpBugga... Hopefully they know what it is or send you a new one asap. No fun having a car that doesn't go :-/
Have you done a reset on the esc??
It flashes green once and then goes black when you turn truck on . when you try to set up throttle it blinks one red light and that's itWhat colour light comes on? Or is there no light?
we just sent esc back to be checked by arrmaSounding like the esc is dead...
Try reseting the esc with the motor unplugged?
I assume the motor is still working?
Youd have to plug it in another car or connect it straight to a battery to see if it is tho
Cool... Hopefully it doesn't take too long for a new one to come or be fixedwe just sent esc back to be checked by arrma
Thanks for all your help it was appreciatedCool... Hopefully it doesn't take too long for a new one to come or be fixed![]()
No worries mateThanks for all your help it was appreciated
