- Kraton 8S
- Mojave
- Notorious
- Senton 6s
- Talion
Another item I'm not using so why not throw it up here . This was for my daughter but turned out she is not really comfortable on it as she can't touch the ground ( thought she would ) . I ride it around a little , it now has 53 miles . Unless you research these there are 2 immediate upgrade / fixers you have to do on them .
1) Carb , the stock one runs very , very lean and starts up hard and takes a long time to warm up . I did the upgrade carb and it runs WAY , WAY better starts up first hit of the starter , even with the choke off . Runs excellent !!!!
2) The rear swing arm rubber bushings as built have slop in them and made the swing arm wobble a bit . Did the Delrin hard plastic solid bushings , now tight as a drum !!!!
3) Added fuel filters , and changed out the crappy oil from factory .
I have the title , I did not reg it so would sign over to whoever buys .
This bike was going to be a replica of the Honda CT70 , tank decals / larger off road tires / raised front fender . I have the new decals , tubes and tires that go with it .
Located in central Ct , can't ship it .
I have $2,150 into the bike as of now , $1,750 takes it with all the extra parts .
