Hector_Fisher
In all fairness, it's basically the HARDEST hit possible.
Skip to 9:15 if you want the carnage.
I saw that when it came out too.
CF, it’s almost 3 times stronger than 7075 and it weighs 2x lessNo chassis would have survived it.
Once it is in a cold enough, the epoxies/resins holding the fibers together become brittle. The chassis would have had some structural problems, even if it wasn't as bad.CF, it’s almost 3 times stronger than 7075 and it weighs 2x less![]()
Had one and although it was very nice, it would have crunched just like that one.Once it is in a cold enough, the epoxies/resins holding the fibers together become brittle. The chassis would have had some structural problems, even if it wasn't as bad.
I think the only chassis that could have survived was one of the JBI 7075 chassis with the built in side guards. Because of the side guards of course.
Edit: I bet the 60+ page on the arrma forum about the sledge is more active than usual...
As someone who just re-entered the ground RC hobby, with a used 6S Sledge, I'm afraid the Sledge thread that I've found here is only 35 pages, and quiet since JulyEdit: I bet the 60+ page on the arrma forum about the sledge is more active than usual...
Laughed as they snapped right in half lolXmaxx/XRT composite would’ve laughed at that.
Even if the chassis survived, good luck with that center driveshaft!Xmaxx/XRT composite would’ve laughed at that.
The notorious is a SWB chassis. That might make a large difference.Didn't he bend an M2C chassis on his Notorious doing basically the same thing?
Is this serious, or funny?After this video, I view M2C as absolute trash and will curse their products all over the internet……
