Ok ok, so the motor is a 1520-1650 castle. It ran fine when I was running on the street, but now that I've made an offroad track and am up to 65% max throttle it heats up pretty fast. I only get about 10 mins before it hits shutoff @ 170. I have the ESC limit motor temp to 180... Though in the logs it says max was 171... Ehhh whatever. The point is... I don't have a heat sink or fan on it. I only went w the 1520 over the 171 because it was 90 grams lighter. If I'm going to put 90 grams of heatsink and fan on it then I'd rather just buy a 1717 and keep fanless. I know the 1520 isn't popular on here but any guesses how much more time a heatsink alone might buy me? Also, it's only 60 degrees out, and I plan to run it in 90 degree weather. Soooo... Yeah...
Oh, I'm already @ a 15t pinion. Is it worth going down another tooth or two? I don't think top speed is going to be an issue if I do, but the only other pinion I have lying around is a 12t and I'm guessing that's too small. Guess it can't hurt to try.
