Shaner319
So after years of wanting to get an rc I finally broke down and bought myself one. The Arrma Vorteks 4×4. After watching videos and seeing all the good things about it I knew it was a good starting point. Boy was I wrong... from the first time I ran it there has been nothing but problems. First it was wheels flying off (I know easy fix) then stripped spur gear (why is it plastic?) Then one of the cvd axles started popping out at the wheel. It wasn't long before it was throwing a couple at a time. Oh wait I forgot about the servo going out after 30 minutes of running. After having it a month I had spent twice as much time working on it or waiting on parts than I did running it. Well I finally decided just to replace all suspension and ordereded the upgraded Arrma cvd slipper axles thinking I was good to go. Well once again I was wrong. Powered it up and took off down the street only to hear a load grinding noise. Now I'm almost $900 into this thing and I get to replace the rear diff. Am I the only one that has had nothing but bad luck from the very start? Maybe it's me idk
