PartsBreaker
6s notorious
How do you run a single 3s battery?
I have the looper connector, when I plug a single 3s it will beep once, then twice, then three times and so on then starts the process over at one beep.
Do I select something at this time if so how?
Also, could I remove the dual plug set up and run a single plug for a 6s battery or a single 3s?
How do you do a factory reset on esc? My throttle trims start going out after a few mins of driving till it just gets worse and worse. Let it sit, and its good for a bit again till its not.
