PartsBreaker
- Thread starter
- #41
Guess this should do ?
The BLX185 ESC DOES run on 3S. Get the manual and reset your ESC.Not 100% sure but I don't think any version of the Notorious supported 3s. Just 4 & 6.
Run a flapper disc over it to smooth it out...... she’ll be right.Sob.....
Finally got everything put back together, ezrun esc, 1650 motor, new motor mount. Took part center diff, it was completely dry added 500k oil, put it all back together. Getting the esc tuned in, turned down the brake setting cause it was doing stopies. Well when its almost at a stop it would slam into reverse. Did this on the concrete, not meaning to, it hoped kinda violently a couple times and I heard it.
The pinion gear was on there sideways and stuck.
Right rightRun a flapper disc over it to smooth it out...... she’ll be right.
Lock that centre diff...........you’ll get your wheelies all day.I think she's cooked
Anyways, gearing.
Seemed to be slower.
It honestly dident seem to have the same power
It no longer tried to do standing back flips.
Not sure if adding 500k fluid to center diff over an empty diff changed how it applied power. Idk what oil if any is in the other diffs....I know, anyways.
The wheelies were really tamed down, it would come up a little then drop back down and go.
Was ok down low, toped out quick.
The top speed, is it lower cause the rpm's of the motor is less?
19t on new motor.
Think old motor had a 15.
Old set up would wheelie all the time and had a decent top speed.
Almost seemed to have lost power and speed everywhere.
