If it is a BLX185 ESC it is a 35mm fanHey everyone. Does anyone happen to know what size the esc fan is on the notorious? Broke a fin off and want to replace the fan but I can’t seem to find what size it is. Thank you
Yes stock 150a escIf it is a BLX185 ESC it is a 35mm fan
https://www.horizonhobby.com/produc...s_65eCjhPWltjl8IAZBmVBV6zKEuMpJ4aAgWUEALw_wcB
I want to say the Firma 150A fan is 35mm. Not a 30mm and not a 40mm. I used a 40mm fan on my Firma 150A but I needed an adapter for the ESC to fit it.
https://www.spektrumrc.com/Products/Default.aspx?ProdID=SPMXSEF2
Yep... 35mm
https://www.amainhobbies.com/spektr...ement-cooling-fan-spmxsef2/p-qqqvt2wqnb2eqctz
Did the 40mm fan hold up better? I am also struggling with the esc fan on a notrious. I live in Florida so it's always hot. It shut off on me in the park yesterday cause the fan broke againIf it is a BLX185 ESC it is a 35mm fan
Yep... 35mm
What adapter did you use on the Spektrum?Yes, the 40mm is holding up good....no issues at all but I am not using the normal 40mm fan it is the Game Changer style, or in some cases, I made my own which is cheaper. I use these on my HW Max6, Firma 150, and Firma 160.
Infraction
The silver adapter was made by our own @Camaroboy383 for the 40mm fans that work with those ESC. He could have some still around.
How many do you need?
Yeah, I have them listed on eBay, same user name as here.. There are also knock off ones listed as well.. so if you want one of mine pay close attention to the user name....Thanks I found them on eBay.
