bicketybam
Back from vacation!
- New Milford, CT
- BigRock 4x4
- Granite
- Infraction
- Kraton 8S
- Kraton 6s
- Kraton 4s
- Mojave
- Notorious
- Talion
- Typhon 6s
Everything is stock except a added heatsink. I did not calibrate the ESC, by that are referring to adjusting its programming settings? That is something I haven't got to yet and I'm not looking forward to because of the cryptic interface (I'm used to programming the ESC with Castle Link).
I'm not referring to programming the ESC (adjusting punch, etc.). I'm talking about calibrating the ESC. There is a section in the manual that explains how to do it. Calibrating the ESC will ensure that when you apply full trottle you actually get full throttle. Same with braking.
Turn on your Tx.
Next to the on/off switch on the truck is a small button. Hold it down and turn on the truck.
Release the button when the ESC starts beeping and flashing red.
With the Tx in neutral press and release that little button next to the on/off switch. The ESC will flash one green light.
Apply full throttle and press/release the button again. ESC flashes 2 green lights.
Apply full brake and press/release the button again. ESC flashes 3 green lights.
Turn off the truck to save the settings.
Done.
