Thanks. Maybe some crunchyness when i turn by hand. Also there is a good amount of resistance. How do I test if it’s the servo?It's servo, also when you make them turn by hand is there any crunchiness or skipping?
Great. Thanks. I’ll look it upI recommend the DS3235 servo for a great value that is fast and strong.
I also recommend taking the bell crank and servo saver apart, cleaning it, replacing any bushings with bearings, and shimming the posts so there is no slop and the servo saver spring so it can handle more force.
I do not personally have one, but......Great. Thanks. I’ll look it up
Hey everyone. Finally got time to mount the servo (Ds3235 35kgs) but somehow the screws that fit my mount are too big for the holes in the servo (see pic). Any thoughts?You probably bricked the servo's gear train. Sounds like what you are describing.
Disconnect/isolate the servo's horn/arm from the ST link and operate the servo, you will clearly see and hear if it is bricked.
DS3235 35kg fits the bill. $34. AMZ. Been extremely good with these as cheap servos go. Have 8 of them.
Servos in bashers are just consumable components in IMO. We beat the crap out of them. Why spend alot.
So the stock arm won't work with the DS35 servo?How I do it. Just buy the correct Arrma 25 Spline Servo horn/Arm. The included Clamping Servo Arm with the DS3235 is NOT the correct length and Profile. It is wrong.
Get the Correct one below.
https://www.arrma-rc.com/en/product/servo-horn-aluminum-black/ARAC8904.html
My set up below on my TLRT... same for all my 6s rigs.
Follow all of what @Engineer stated for installation.
Servo must "float" above and not touch the chassis. A few mm is enough. Shim as needed. Can use "servo shims" or similar if needed.
Thanks, yeah I found out in another thread the servo i ordered lastnight was also 25T seems all the aftermarket ones from Spektrum are 25 so i ordered that arm also.No it will not.
The 23 spline Spektrum arm/horn is an outliar. And Spektrum likes it that way. So you keep buying their $servos$.
99% of of upgrade servos Are 25 spline. Including the DS3235 AMZ servo. The nice Universal clamping 25 spl. Arm that comes with the DS3235 is not the best fit IMHO. Some have made it work. I tried. I rather just use the Arrma 25 spline servo arm.
And all Arrma rigs in the past, only several years back, were always 25 spline to begin with, until Spektrum started pushing/marketting their own servo's.
Just get the Arrma 25 spline arm for the a 6s rig. And don't look back.
This was the Old legacy Stocker 25 Spline servo arm below. Now it is an "Option" part. Plug and play. Proper profile and correct fit. Most that are new to Arrma, don't know this.
