Senton Now all I need is the TLR Typhon !!
3x9rtse
  1. Kraton 8S
  2. Mojave
  3. Notorious
  4. Senton 6s
  5. Talion
Since Arrma won't make it , I'll make one myself !!!! I now have all the parts for the Senton 6s to make another Typhon into a Senton 6s build ( did it to a V2 Typhon few years ago ) . Rather than do it to a RTR Typhon , I'm going to pick up a TLR Typhon and make my own TLR Senton 6s !!!!
Because of the shock towers having the tunable sections for the pills , I will have to leave those and modify the Senton body mounts to fit them . Also , will be leaving the wider Typhon arms for better stability/ handling , and NTM , if I break one , easy to get .
Watch , I'll be just finishing it , and Arrma will release one , or an EXB roller Senton 6s !!!! LOL
I'm horrible , gonna have 2 Senton 6s shelf queens !!!
As a Senton lover, I approve this message. What tuyos of wheels are you going to run?
Well , I was thinking if the Typhon 1/8 tires fit under the body , those and the Powerhobby SC Defenders you see on the Senton on the left in my picture . They are a little beefer than the stock ones .
I ask since you are running the Typhon arms, buggy wheels should stay well within the body.
When I did my last Typhon / Senton conversion I also left the Typhon arms and buggy tires but was running a different body on it , so I don't know how this is going to work out with trying to use a Senton 6s body , if they rub or hit to hard , I might buy a Proline or Jconcepts body . The one in this pic is a Jconcepts . These are what I use on my Losi SCTE 3.0
Oooooh , idea , I'll get a new one of these and paint it up to look like an EXB body !!!!
Any take off parts you do not need, I am trying to have some 1st dibs :) Feel free to PM me.
This seems like a cool project BTW.
I'm actually gonna keep all the Typhon parts removed for this build just in case I want to transfer it back to a Typhon .
Body doesn’t rub ?
Thanks.
Believe it or not , the back just misses , the front at full compression does land on the tire . I'm going to drive easy at first to see what happens . BTW, this is with the bigger and wider Powerhobby Defender belted tires . I will try the stock ones to see what it looks like . NTM , I have an old JConcepts body that def clears all around .
+1.
I agree.
If you source zero offset 1/8 Buggy wheels (must be zero offset), they should tuck neatly under the Senton SCT body. One option.
Are the stock sidewinders any good? Just nobody seems to use them!
I heard they wear out fast?:unsure:
No personal experience with them however.
+1.
I agree.
I have the Typhon 1/8 tires that I removed from the Typhon that I could put on, but I wanted to stay with SCT tires
I put on the orig Senton tires and the 1/8 buggy Typhon tires . After closely examining them , the Powerhobby Defenders have a greater offset,see pic . The Typhon tires clear , as well as the Senton Dboots, but I really want to run the Powerhobby as they are more aggressive and are belted. Will try the Typhon tires though.
Pics
