Well after the recent installs and upgrades I did to my new Outcast 4s I finally got out and drove it a bit. I immediately noticed something just wasn't right. It was driving weird. I wasn't sure what it was but it felt diff related. Anyway after doing a pretty cool unintentional cart wheel I snapped a turn buckle in half. So that was that for my Outcast. Since its out of commission I decided to take a look at the diffs, and now I understand why its recommended to check these asap. First thing that happened was one of the screws that holds the drive shaft to the diff was SUPER THREAD LOCKED. So much so that after turning a little the screw head stripped. So to be able to get the drive shaft out I had to use a Dremel and cut all the plastic off around the screw so I could hold it with pliers. I finally got it out, but of course that drive shaft yolk is shot. See attached pic. Well after having so much trouble with that one I expected the same from the other side. It was the total complete opposite. It was literally finger loose. After getting the screw out there was no thread lock at all on that side.
Anyway once I got the diffs out I cracked them open and they were less than half full. Maybe a 1/4 full if that? Which also leads to a question. I am planning on using some 10k to refill them once I get the parts I need as well as the Jims bearing kit I ordered. I know on the 6s you almost completely fill them. For the 4s diffs is it the same? The 6s manual shows it being filled like 1mm less than full. So what is the correct level for the 4s diffs?
Anyway I have all the parts I need ordered as well as a Horizon parts request I sent in. While the Outcast was running it was a blast. So fast. So looking forward to getting it dialed in the same way my Notorious is. Thanks for the help.
