Could use some help from some of you Typhon gurus! So I tried the trick taking a couple of 14 mm O-rings to support the front and the back of the motor on my brushless 3S. It’s happened twice now that after I run it the front O-ring is cut in half but the rear one is fine. Anyone else have this issue? Am I using the right size O-ring? Thanks in advance!
