500k
Welp, has to be too much stress on the plastic cups. Do they make aluminum cups for this yet?
500k
8s metal diff cases coming
https://www.horizonhobby.com/product/metal-diff-case-set/ARA310975.html
I don't get it either. Every one is saying how good these diffs are yet some of us are having major problemsWeird. I run 12s in mine and haven't had a singular diff problem yet.
I think once these metal diff cups are installed, the diffs will be pretty much bulletproof.I don't get it either. Every one is saying how good these diffs are yet some of us are having major problems
Wow, I see!!!Here’s your answer...
View attachment 103251View attachment 103252View attachment 103253View attachment 103254
I already posted this in the what did you break today thread, thought I’d add it here too.
https://www.arrmaforum.com/threads/what-did-you-break-today.8928/post-396984
So It can withstand a nail gun???I think the K8S Arrma body is the most durable one they make. It's tough as nails.
Wow, haven't seen that beforeHas anyone seen upgraded front upper hinge pins? I keep snapping these off at the threads. This is the part im talking about https://www.amainhobbies.com/arrma-8s-blx-5x74mm-hinge-pin-2-ara330564/p1148678
I emailed M2C to see if they have plans on making any.
M2C said they don't have any plans to make the part at this time. I have snapped like 3 or 4 already. I guess i'm a crappy driverWow, haven't seen that before
bulletproof bodyI think the K8S Arrma body is the most durable one they make. It's tough as nails.
This is me just saying this. Buy you some aluminum at the thickness you need. use some power tools and cut it out and work it in so it fits like you want. these plastic shock towers stock are awesome for the Outcast 8S. I only say this because I would like to see some homw made parts that aren't CNC machined. Yes, I know.. this guy is weird but when your done its your custom build and you learn a lot.M2C said they don't have any plans to make the part at this time. I have snapped like 3 or 4 already. I guess i'm a crappy driver
Yea i actually got some 5MM threaded rod and put lock nuts on both ends. It seems to be working, but is a pain to remove because of the location of the nut on the inside area. it has bent slightly but not broke. I bought some stock replacements that I will prob put in when i rebuild the front end tonight or tomorrow. I am replacing the front gearbox housing because i found that 2 of the screws holding the steering top plate are stripped, and i think that may have been giving some play that contributing to the breakage of the upper hinge pins. Thanks!bulletproof body
I got the 7075 aluminum it’s awesome here some picsJust bash it rc do an alternative chassis to the M2C, if you don't want to change the wheelbase and mess about cutting body shells.
https://justbashitrc.com/shop/pre-order-only-kraton-8s-jbirc-7075-t651-aircraft-grade-aluminum/
Any one use these yet? I Broke a drive shaft today and these are the same price as stockers but 1.5mm thicker.Has anyone tried these aftermarket driveshafts for the K8S? I bent my stock 5mm ones between my first and second run. They claim that they are tougher than stock at 7mm thick ?
https://www.jteamhobbies.com/products/makx181f0rs-bk
They are meh. They did bend as much as stock with time. Some other people mentioned that the pin that goes into the drive cups can snap off easily too. I tried them on my K8S and they bent after a few bad landings. It did take longer to bend them, but I was able to. Also in the front, one of them broke inside the hub (the cvd part). So yeah they are weren't that good. The best thing to is not to land on one wheel or cartwheel.Any one use these yet? I Broke a drive shaft today and these are the same price as stockers but 1.5mm thicker.
I’d be willing to invest in all four corners if someone has had good experience with them.
Thank you. The part that goes inside the cup snapped clean offI’ve def had some questionable landings and more than a few cartwheels. I’m surprised nothing else broke and it didnt happen sooner.They are meh. They did bend as much as stock with time. Some other people mentioned that the pin that goes into the drive cups can snap off easily too. I tried them on my K8S and they bent after a few bad landings. It did take longer to bend them, but I was able to. Also in the front, one of them broke inside the hub (the cvd part). So yeah they are weren't that good. The best thing to is not to land on one wheel or cartwheel.
This looks siiiick! Have you tried em?Vitavon 7075 ally steering bell crank for the 8s models with increased turning angle.
https://www.ebay.com/itm/Vitavon-re...500242?hash=item422465e992:g:5dUAAOSwnclfriCr
Not yet.This looks siiiick! Have you tried em?
