bluedeval03
pulled the trigger and ordered my Typhon a couple weeks back and a bunch of goodies also. Hot Racing full steering set up-diff cups-Fast Eddies bearing kit-Mugen 0206 shim kit-100k and 10k silicone oils-SMC 4s batts-3 piece rear axle dirt cover set-full sets of Duratrax Lock Ups, Six Pack, & Bandito. What is typical run time that you guys are getting out of the stock bearings or just go ahead and swap them in while everything is already apart for shimming etc?
Have been looking at the Voltage goodies and trying to decide what I should pick up next say the suspension mounts in aluminum? Or is the Typhon as good as I read out of the box? I am open to any suggestions for parts and what nots to have on hand as well.
Already trying to decide which Arrma I want to add next!!! New Notorious is sweet, but also like the Kraton too many choices.
The first mod I have done so far on it was to help counter the high temps I read about. I noticed there isn't much room for air to get up under the body so I took my Dremel and removed each side window to get more air in. I was going to do just the windshield, but I have always had great luck through the years doing the side.
Thanks
David
Thanks
David
