I was looking for suggestions on diff oil for front, center, and rear... also, what should I use to live my bearings? Grease etc....... also looking to venue the shock oil, what should I use for that also?..
I use Losi and Team Associated shock oil and diff lube. I usually get it from Horizon Hobby stores, or, if i don't need it right away, ill have it shipped, since the nearest HH store is 120 miles from me. For O-Ring grease, its probably not the correct stuff, but, so far, i haven't had any issues, but i use Oateys 100% silicone plumbing grease from Lowes. It comes in a small round white container, and here it is about $4, versus the green slime grease that is a bit expensive for a small tube. For bearings, i use a needle applicator bottle i got from Hobby Lobby, and sewing machine oil. As i don't have a Kraton, i wont try and guess which oil weights to use with it. Someone else should have a proper answer for that question though.I was looking for suggestions on diff oil for front, center, and rear... also, what should I use to live my bearings? Grease etc....... also looking to venue the shock oil, what should I use for that also?..
The stuff most people recommend for O-rings is this: https://www.amainhobbies.com/team-associated-factory-team-green-slime-asc1105/p3068OK, do you know what the proper stuff is for the O-rings? For all I know, it could be called bearing grease LOL I got a new bearing kit but I don’t want them to squeak like hell ?
