- Thread starter
- #101
Thanks! I do try to make it my own.Love the creativity.i love building rides I've never,ever seen anyone else do...never saw anyone go this route..I've scrolled but,will it be 2wd??I run wider track on the rear of my speedcars ,seams to help them go straighter..imo my only concern with your build would be the shock towers getting bent easily.thats why mojaves are always breaking body mounts...I always put foam on top of towers to help from bending them..I know you bash like me..planted to the ground an hauling A$$...
Low and sleek is the idea. The limitless towers fit without issues? What about the body mount location/distance from eachother?ill check if i got pics,could always go with smaller towers,limitless are the smallest.with shorter towers ya can get the body lower.....set of limit towers are like 6$ on jrc....
I do have plans for the openings but I'm sure will only help so much...sand is going to get everywhere! hahaid try to block off every opening around body to try an keep sand out,mount body then block off........outcast has the wings up front that would probly help..those tires will throw sand everywhere.you running a spool?
when i do custum builds i figure body mounting last...i always just wing it.......between all the diffrent arrma body mounts youll figure the mounts out
Not sure if you've ever read this thread I did few years ago.Thread 'HOW TO BUILD YOUR OWN CUSTOM ARRMA' https://www.arrmaforum.com/threads/how-to-build-your-own-custom-arrma.29731/
Wow some information stuff!Get all the 3s body mounts an all the 6s mounts...a must for mounting custom bodys..most the 3s mounts will fit all the arrma bodys.ive drilled new holes in towers an used the noto mount supports with 3s mounts like
these.bet one of the 3s would fit talion front perfectly
Bet senton 3s front fits???
BTW. There's nothing (you can't do in this hobby).that's why I love tha hobby.can make,do whateverWow I may need to rethink my towers.
I'm wondering if I would have to change my front shocks also though if I was to go with lower towers...? Thats something I wouldnt be able to do.
I think with it fully loaded with all the electronics and batteries it will sit at the right height. Hers a picture as it stands without the electronics and one with me holding down the front end at the height I'm shooting for.
View attachment 206669View attachment 206670
Not shown is the Mojave side guards that will be used.
I appreciate it all.Looks awesome,I'd just keep on going with what ya got...just giving ya some ideas for next build..
Yes you would need shorter shocks with smaller towers...
Any time brother,I appreciate it all.
Always good to get thoughts ideas and advice!
That would look pretty bada$$!If your still wanting to get the body lower you could try something similar to this. Cut a opening in the hood and let the shocks come through. Would take some time to make it look clean but could get the body down.
Here is some more inspiration.
